Einleitung
Make sure you have a replacement ready! This will involve some drive formatting.
  1. Remove the nine Phillips screws using a Philips 00 screwdriver Remove the nine Phillips screws using a Philips 00 screwdriver Remove the nine Phillips screws using a Philips 00 screwdriver
    • Remove the nine Phillips screws using a Philips 00 screwdriver
  2. Pry up the case carefully using a spudger. Make sure to not push the spudger in too far, as this could result in internal damage
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. Lift off the cover, and you're done!
    • Lift off the cover, and you're done!
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Carefully remove two Phillips screws with a Phillips 0 screwdriver Static sensitive components!
    • Carefully remove two Phillips screws with a Phillips 0 screwdriver
    • Static sensitive components!
  6. Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
    • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
  7. Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides). Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
    • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
  8. Carefully remove the SSD enclosure. Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
    • Carefully remove the SSD enclosure.
    • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Tanner Lange
969 Reputation
3 Anleitungen geschrieben
Francophones Mitglied von Francophones
Community
7 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 97
Insgesamt: 1,189
