Zum Hauptinhalt wechseln
Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement
Was du brauchst
  1. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, J1 Screws on Throttle: Schritt 1, Bild 1 von 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: Schritt 2, Bild 1 von 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: Schritt 2, Bild 2 von 2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: Schritt 3, Bild 1 von 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: Schritt 3, Bild 2 von 2
    • Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
  4. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 4, Bild 1 von 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 4, Bild 2 von 2
    • Pull the panel that is covering the R2 button away from the throttle.
  5. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 5, Bild 1 von 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 5, Bild 2 von 2
    • Carefully push the R2 button from the outside of the panel.
    • Be cautious of the spring attached to the button as it can be easily lost.
  6. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 6, Bild 1 von 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
  7. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 7, Bild 1 von 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: Schritt 7, Bild 2 von 2
    • Carefully push the L2 button from the outside of the panel.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Mitglied von CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Mitglieder
13 Anleitungen geschrieben
Ein Kommentar
Hello, m R2 button is broken. Do you know where i can print a new one ?
louis_tiquet - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,295
