Was du brauchst
Start by flipping it over, rest it on the pedals. make sure the wire is pointing towards the bottom. remove the 14 Screws on the back with a PH2 Phillips head screwdriver and carefully pop it off.
Once the bottom is separated, remove the glue holding the wire and pull it out.
For reassembly, simply follow the steps in reverse.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
