Einleitung
Use this guide will show how to replace the USB cable.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Was du brauchst
Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
Gently pull apart both halves of device to access inside.
Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
kunt u mij vertellen waar ik het kabeltje kan kopen?
Rene
Can you advise on where to obtain a new usb cable please? (clentonmalcolm@gmail.com)
Have you solved it? I'm worried it's different from the regular usb line.
sunned -
Then wat where do u get usb cord to replace it some one plz explian
Oh man.. the first comment about this was 2019 and we both are still waiting for an answer huh
