Einleitung
Use this guide to replace the motherboard of your Thustmaster Ferrari 458 Spider Racing Wheel.
Was du brauchst
Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
Gently pull apart both halves of device to access inside.
Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
Cut the black cable as close to the board as possible.
Remove the three screws using PH2 screw driver.
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare
Just so every one knows its easier then changing a baby's arse for the first ten times if any one hasn’t yet I'm not gunna paint a picture I'm just going to sit here and smile. But as I was saying I found what was wrong just got to get my parts and fit as easy as that and if you don't know or butter for fingers then just let some other capable suspect do it, Save money.
Where did you get a replacement motherboard?
