Einleitung
To fix any component inside the TiVo, this is important to understand how to first take off the first piece of equipment so the user can handle the rest.
Was du brauchst
Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
Fast fertig!
Ziellinie
