Einleitung
The hard drive is the component capable of storing recordings. This information is vital in case the TiVo does not record the desired shows.
Was du brauchst
Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
Pinch the connector of the bundle of wires (the bundle having black, red, black and yellow wires) and gently remove from the motherboard.
Pinch the connector of the single flat wire and gently remove from motherboard.
Unscrew the following two 80 mm T10 screws connecting the hard drive to the bottom of the box using the Torx screwdriver.
Repeat on the other side of the hard drive.
There will be a total of four 80 mm T10 screws removed.
Remove the marked (2) T10 screws and washers using a Torx Screwdriver.
Repeat on the opposite side for (2) T10 screws.
Remove the connecting cable.
