Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide describes how to replace the hard drive.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  5. Locate the hard drive.
    • Locate the hard drive.
  6. Remove the ribbon cable by applying firm pressure to the black tabs on the sides. Remove the power cable to the right of the ribbon cable.
    • Remove the ribbon cable by applying firm pressure to the black tabs on the sides.
    • Remove the power cable to the right of the ribbon cable.
  7. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
    • Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
Abschluss
Talha
31 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-33, Amido Fall 2011 Mitglied von Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 1,556
