Einleitung
The power supply allows for the TiVo components to work. In the situation that it needs to be replaced, this guide will walk you through the installation of the power supply
Was du brauchst
Remove the belt connecting the power supply to the motherboard by pulling it out.
Remove the red, yellow, and black cable connecting the power supply to the hard drive.
Pinch the plastic plugs and lift the power supply up to detach from plugs.
All 4 plugs must be detached to remove power supply.
