Einleitung
In case your remote just won't work and you have already tried replacing the batteries, this guide will walk you through removing the front cover and replacing the remote sensor on the inside of the cover.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Unplug the ribbon cable from the motherboard. Some force may be required for this step, so be careful not to rip the ribbon cable.
    • Unplug the ribbon cable from the motherboard. Some force may be required for this step, so be careful not to rip the ribbon cable.
  6. Unscrew the two 0.31 inch T-9 screws on the inside of the front cover.
    • Unscrew the two 0.31 inch T-9 screws on the inside of the front cover.
  7. Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover. Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover. Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover.
    • Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover.
  8. Pull the front cover down and away from the device to separate it completely. Be careful not to tear the ribbon cable as you are removing the front cover.
    • Pull the front cover down and away from the device to separate it completely. Be careful not to tear the ribbon cable as you are removing the front cover.
  9. Unscrew the two 0.31 inch T-9 screws on the back of the sensor.
    • Unscrew the two 0.31 inch T-9 screws on the back of the sensor.
  10. Lift the sensor up to remove it.
    • Lift the sensor up to remove it.
Abschluss
Shauna
37 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-33, Amido Fall 2011 Mitglied von Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Mitglieder
7 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 905
