Zum Hauptinhalt wechseln
TiVo Series 2 TCD540080 Hard Drive Replacement
Was du brauchst
  1. TiVo Series 2 TCD540080 Hard Drive Replacement, Removal of TiVo Series 2 TCD540080 Case: Schritt 1, Bild 1 von 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Hard Drive Replacement: Schritt 3, Bild 1 von 2 TiVo Series 2 TCD540080 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Disconnect the power to the hard drive.
  5. TiVo Series 2 TCD540080 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Grab the hard drive data cable from both sides of the connector and unplug it from the hard drive.
    • Use extreme caution when unplugging connector and do not disconnect the data cable by pulling on the cable itself.
  6. TiVo Series 2 TCD540080 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the two screws on the case of the hard drive with a T10 screwdriver.
    • Pull the hard drive up and out of the TiVo unit.
  7. TiVo Series 2 TCD540080 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Unscrew the four screws, shown in the picture, with a T-10 screwdriver.
    • Remove the hard drive from the case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 33-79, Johann Spring 2010 Mitglied von Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 7,639
