Was du brauchst
Power down the TiVo and detach the power cable from the rear of the unit.
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
Grab the hard drive data cable from both sides of the connector and unplug it from the hard drive.
Unscrew the two screws on the case of the hard drive with a T10 screwdriver.
Pull the hard drive up and out of the TiVo unit.
Unscrew the four screws, shown in the picture, with a T-10 screwdriver.
Remove the hard drive from the case.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
