Was du brauchst
Power down the TiVo and detach the power cable from the rear of the unit.
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
Unscrew the two black screws on the left with a T8 Torx Screwdriver.
Disconnect the connector cable that goes to the lights on the front of the device.
Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
Eine weitere Person hat diese Anleitung absolviert.
