Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide is for if you conclude that your difficulty with braking is due to your brake cables being too loose.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
    • Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
  2. Pull the brake cable until proper tension is acquired and the cable shows resistance.
    • Pull the brake cable until proper tension is acquired and the cable shows resistance.
  3. Re-tighten the clamping nut.
    • Re-tighten the clamping nut.
  4. If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
    • If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
  5. For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
    • For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
Abschluss
Your brakes should be fully tightened now.
10 weitere Nutzer haben diese Anleitung absolviert.
Samantha Rawlins
458 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 1-40, Maness Winter 2014 Mitglied von Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Mitglieder
5 Anleitungen geschrieben
Thank God I didn’t have to watch someone's long winded 10 minute video explaining this.  lol Thank you for that!  Great article.  Thanks for helping me out!
rtinmotion - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 21
Insgesamt: 2,447
