Zum Hauptinhalt wechseln
Timbuk2 - Tuck Pack Tuck Clip Replacement
Was du brauchst
  1. Timbuk2 - Tuck Pack Tuck Clip Replacement, Gearing up: Schritt 1, Bild 1 von 2 Timbuk2 - Tuck Pack Tuck Clip Replacement, Gearing up: Schritt 1, Bild 2 von 2
    • Before beginning your repair, contact repairs@timbuk2.com to obtain a replacement tuck clip.
  2. Timbuk2 - Tuck Pack Tuck Clip Replacement, Remove old clip: Schritt 2, Bild 1 von 1
    • Using wire cutters or heavy duty scissors, break off old tuck clip and remove from fabric.
    • Insert scissors in the space between the strap and the buckle's first loop and cut through.
    • Next, insert scissors in second loop between the strap and the buckle's second loop and cut through. (It is easier to cut on the inside edges of the loops than to cut the loops in the center)
  3. Timbuk2 - Tuck Pack Tuck Clip Replacement, Make loop: Schritt 3, Bild 1 von 1
    • Take Strap and fold in half to make a loop shape
  4. Timbuk2 - Tuck Pack Tuck Clip Replacement, Insert loop of strap: Schritt 4, Bild 1 von 3 Timbuk2 - Tuck Pack Tuck Clip Replacement, Insert loop of strap: Schritt 4, Bild 2 von 3 Timbuk2 - Tuck Pack Tuck Clip Replacement, Insert loop of strap: Schritt 4, Bild 3 von 3
    • Insert one side of the loop in the middle section of the clip
    • Hook the loop on one of the middle pegs
    • Take pliers and pull up the loop that is around the peg
  5. Timbuk2 - Tuck Pack Tuck Clip Replacement, Pull through then done!: Schritt 5, Bild 1 von 2 Timbuk2 - Tuck Pack Tuck Clip Replacement, Pull through then done!: Schritt 5, Bild 2 von 2
    • Using the pliers, grab the other side of loop and pull it over the other middle peg
    • Pull strap down and DONE!
Abschluss
Pull strap through clip, tdown and DONE!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Timbuk2
583 Reputation
3 Anleitungen geschrieben
Ein Kommentar
I used an exacto knife to pull the original threads of the strap end out so I could remove the clip without cutting the strap. I then threaded the new clip in as shown above, but also folded back the end of the strap to its original sown point, and then used a heavy duty stapler with a 3/8" staple to staple the fold in place. This keeps the strap from coming undone from the clip - same as originally installed.
jeffrey peckham - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 12
Letzte 30 Tage: 32
Insgesamt: 3,747
