Zum Hauptinhalt wechseln
Timex W-10 Children's Watch Battery Replacement
Was du brauchst
  1. Timex W-10 Children's Watch Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Timex W-10 Children's Watch Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Timex W-10 Children's Watch Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Pull on the watch strap through the top of the strap buckle to unlock the strap.
  2. Timex W-10 Children's Watch Battery Replacement: Schritt 2, Bild 1 von 2 Timex W-10 Children's Watch Battery Replacement: Schritt 2, Bild 2 von 2
    • Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
  3. Timex W-10 Children's Watch Battery Replacement: Schritt 3, Bild 1 von 2 Timex W-10 Children's Watch Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
  4. Timex W-10 Children's Watch Battery Replacement: Schritt 4, Bild 1 von 2 Timex W-10 Children's Watch Battery Replacement: Schritt 4, Bild 2 von 2
    • Gently remove the back plate to expose the battery.
  5. Timex W-10 Children's Watch Battery Replacement: Schritt 5, Bild 1 von 2 Timex W-10 Children's Watch Battery Replacement: Schritt 5, Bild 2 von 2
    • The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tarik Ihmoud
128 Reputation
1 Anleitung geschrieben
2 Kommentare
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - Antwort
Daniel Melendrez - June 12
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 46
Insgesamt: 8,144
