Einleitung
If your Timex W-10 children's watch needs a battery replacement, this guide will help if there are any questions concerning how to change the battery.
Was du brauchst
Pull on the watch strap through the top of the strap buckle to unlock the strap.
Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - June 12
