Einleitung
The Tineco FLOOR ONE S3 Breeze (model no. FW007600US) will sometimes have charging issues with the battery, and this causes it to become less efficient over time, which may result in the need to replace the battery. This replacement guide shows all the steps required to replace the battery and get the vacuum back in operation.
Was du brauchst
Remove six 10.6 mm screws from the back of the vacuum with a Phillips #1 screwdriver.
Remove the entire back piece.
Remove four 10.6 mm screws from the remaining white back piece with a Phillips #1 screwdriver.
Pry open and remove the black ring at the top of the vacuum using by using an opening tool.
Remove four 10.6 mm screws located underneath the previously pried ring using a Phillips #1 screwdriver.
Remove the top circular piece from the body of the vacuum.
Unplug the wires of the battery by carefully pulling them up from the motherboard.
Slide the battery out of its slot and replace it with the new battery.
