Einleitung
The Tineco FLOOR ONE S3 (model no. FW007600US) may exhibit erratic behavior or complete system failure. This is usually caused by failure of the motherboard. Follow these steps to replace the motherboard.
The motherboard is an essential component to this floor cleaning machine. It is the main computer that tells the motors to go when certain buttons are activated. The vacuum would not be able to operate without the motherboard.
Was du brauchst
Remove six 10.6 mm screws from the back of the vacuum with a Phillips #1 screwdriver.
Remove the entire back piece.
Remove four 10.6 mm screws from the remaining white back piece with a Phillips #1 screwdriver.
Pry open and remove the black ring at the top of the vacuum using by using an opening tool.
Remove four 10.6 mm screws located underneath the previously pried ring using a Phillips #1 screwdriver.
Remove the top circular piece from the body of the vacuum.
Unplug the wires of the battery by carefully pulling them up from the motherboard.
Slide the battery out of its slot and replace it with the new battery.
Remove the four 10.6 mm screws holding the motherboard using a Phillips #1 screwdriver.
Carefully remove the motherboard from the vacuum.
