Zum Hauptinhalt wechseln
Tineco FLOOR ONE S3 Breeze Motor Replacement
Was du brauchst
  1. Tineco FLOOR ONE S3 Breeze Motor Replacement, Wheels: Schritt 1, Bild 1 von 2 Tineco FLOOR ONE S3 Breeze Motor Replacement, Wheels: Schritt 1, Bild 2 von 2
    • Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
    • Remove the first plastic cover.
  2. Tineco FLOOR ONE S3 Breeze Motor Replacement: Schritt 2, Bild 1 von 2 Tineco FLOOR ONE S3 Breeze Motor Replacement: Schritt 2, Bild 2 von 2
    • Remove twelve 10.6 mm screws from the second plastic cover with a Phillips #1 screwdriver.
    • Remove the second plastic cover.
  3. Tineco FLOOR ONE S3 Breeze Motor Replacement: Schritt 3, Bild 1 von 2 Tineco FLOOR ONE S3 Breeze Motor Replacement: Schritt 3, Bild 2 von 2
    • Remove two 10.6 mm screws holding the wheels in place with a Phillips #1 screwdriver.
    • Remove the wheels.
    • The wheels do not need to be removed to access the motor.
  4. Tineco FLOOR ONE S3 Breeze Motor Replacement, Motor: Schritt 4, Bild 1 von 1
    • Remove the motor and the brush arm.
  5. Tineco FLOOR ONE S3 Breeze Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove three 10.56 mm screws from the gear with a Phillips #1 screwdriver.
  6. Tineco FLOOR ONE S3 Breeze Motor Replacement: Schritt 6, Bild 1 von 1
    • Simply pull by the base of wires to remove them from the motor.
    • Remove the gear from the brush arm.
Abschluss
Luke Guess
199 Reputation
2 Anleitungen geschrieben
University of Memphis, Team 3-5, Sneed Spring 2024 Mitglied von University of Memphis, Team 3-5, Sneed Spring 2024
UM-SNEED-S24S3G5
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 82
Insgesamt: 2,140
