Einleitung
The Tineco FLOOR ONE S3 Breeze (model no. FW007600US) will sometimes have problems with the wheels wearing out over time, and it may need to be replaced by removing the wheel cover plate and removing the existing wheels. After a quick reassembly the machine is ready to operate. This replacement guide contains the following steps for the wheels replacement.
The wheels are what allows the vacuum to move and clean efficiently. If the wheels are broken, then the vacuum is just about useless.
Was du brauchst
Place a finger on the lever located on the brush roller cover.
Firmly push the lever with a finger to remove the brush roller cover.
Grasp the brush roller on its side.
Pull the brush roller out of its initial position.
Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
Remove the first plastic cover.
Remove twelve 10.6 mm screws from the second plastic cover with a Phillips #1 screwdriver.
Remove the second plastic cover.
Remove two 10.6 mm screws holding the wheels in place with a Phillips #1 screwdriver.
Remove the wheels.
