Einleitung
This guide will teach you how to properly disassemble a Toastmaster toaster over and replace the toasting knob. Before you begin, clean out your toaster oven and make sure it is off and unplugged.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the two 4mm by 8mm screws from the back of the toaster oven.
Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
Take the two supports off of the bottom.
Grip the sides of the metal cover and lift the cover up off the toaster oven top.
The knob is missing in the first picture.
Push the knob into the hole.
The knob is now back in place in the last picture.
