Zum Hauptinhalt wechseln
Toastmaster W252C Disassembly
Was du brauchst
  1. Toastmaster W252C Disassembly, Toastmaster W252C Disassembly: Schritt 1, Bild 1 von 2 Toastmaster W252C Disassembly, Toastmaster W252C Disassembly: Schritt 1, Bild 2 von 2
    • Remove the 10 mm flathead screw from the top half of the device.
  2. Toastmaster W252C Disassembly: Schritt 2, Bild 1 von 3 Toastmaster W252C Disassembly: Schritt 2, Bild 2 von 3 Toastmaster W252C Disassembly: Schritt 2, Bild 3 von 3
    • Use a spudger to pry the top metal casing away from the burner and fully open it.
  3. Toastmaster W252C Disassembly: Schritt 3, Bild 1 von 3 Toastmaster W252C Disassembly: Schritt 3, Bild 2 von 3 Toastmaster W252C Disassembly: Schritt 3, Bild 3 von 3
    • Remove the 10 mm flathead screw attaching the metal plate to the cooking surface.
    • Separate the metal plate from the cooking surface.
  4. Toastmaster W252C Disassembly: Schritt 4, Bild 1 von 2 Toastmaster W252C Disassembly: Schritt 4, Bild 2 von 2
    • Flip the waffle maker over and remove the 10 mm flathead screw from the bottom surface.
  5. Toastmaster W252C Disassembly: Schritt 5, Bild 1 von 3 Toastmaster W252C Disassembly: Schritt 5, Bild 2 von 3 Toastmaster W252C Disassembly: Schritt 5, Bild 3 von 3
    • Use your hands to pull the heat settings knob away from the front of the bottom half.
    • Remove the bottom cooking surface from the metal shell.
  6. Toastmaster W252C Disassembly: Schritt 6, Bild 1 von 2 Toastmaster W252C Disassembly: Schritt 6, Bild 2 von 2
    • Remove the 10 mm flathead screw from the inside of the bottom half.
  7. Toastmaster W252C Disassembly: Schritt 7, Bild 1 von 2 Toastmaster W252C Disassembly: Schritt 7, Bild 2 von 2
    • Unscrew the 22.5 mm flathead screw and remove the switch from the bottom cooking surface.
  8. Toastmaster W252C Disassembly: Schritt 8, Bild 1 von 1
    • You can now separate all the components from the bottom half of the waffle maker.
  9. Toastmaster W252C Disassembly: Schritt 9, Bild 1 von 2 Toastmaster W252C Disassembly: Schritt 9, Bild 2 von 2
    • Remove the plastic clips holding the resistor by simply maneuvering them so that they fall out of the hinge.
  10. Toastmaster W252C Disassembly: Schritt 10, Bild 1 von 2 Toastmaster W252C Disassembly: Schritt 10, Bild 2 von 2
    • The Toastmaster W252C has a Reparability Score of 6 out of 10 (10 is easiest to repair)
    • Disassembling the device is easy. A single flathead screwdriver is needed to take care of all the screws.
    • The disassembly is straightforward. There are no hidden screws or glue.
    • Since the W252C is so old, there are little to no replacement parts online unless you buy another W252C and take it apart, which defeats the purpose of repairing it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Angehängte Dokumente
Ein Kommentar
Do you know what the different model number letters mean? I just found a W252F. Looks just like the model you show. Just wondering what the F means vs C. Thanks
Nancy Dinoto - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 979
