Zum Hauptinhalt wechseln
Tofu65 Keyboard PCB Replacement
Was du brauchst
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: Schritt 1, Bild 1 von 1
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: Schritt 2, Bild 1 von 1
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: Schritt 3, Bild 1 von 1
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: Schritt 4, Bild 1 von 2 Tofu65 Keyboard PCB Replacement: Schritt 4, Bild 2 von 2
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: Schritt 5, Bild 1 von 2 Tofu65 Keyboard PCB Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: Schritt 6, Bild 1 von 3 Tofu65 Keyboard PCB Replacement: Schritt 6, Bild 2 von 3 Tofu65 Keyboard PCB Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: Schritt 7, Bild 1 von 2 Tofu65 Keyboard PCB Replacement: Schritt 7, Bild 2 von 2
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: Schritt 8, Bild 1 von 2 Tofu65 Keyboard PCB Replacement: Schritt 8, Bild 2 von 2
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: Schritt 9, Bild 1 von 3 Tofu65 Keyboard PCB Replacement: Schritt 9, Bild 2 von 3 Tofu65 Keyboard PCB Replacement: Schritt 9, Bild 3 von 3
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: Schritt 10, Bild 1 von 2 Tofu65 Keyboard PCB Replacement: Schritt 10, Bild 2 von 2
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Daniel Payan
202 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-2, Grodsky Spring 2024 Mitglied von CSU Los Angeles, Team 2-2, Grodsky Spring 2024
CSULA-GRODSKY-S24S2G2
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 59
Insgesamt: 789
