Einleitung
This guide is made to show you how to replace a super capacitor battery from the Toguard C200 model. If you are experiencing difficulties charging the camera or keeping the camera on even after charging it, a battery replacement should fix the problem.
Note: This C200 dash cam needs to be connected to a 5V 2A external power supply when in use to stay powered on.
Was du brauchst
Use a Phillips screwdriver to unscrew the 4 screws to access the battery underneath.
Lift the motherboard slightly.
Use the tweezers and your hands to remove the battery from its original place.
Desolder the old battery.
Heat the solder by using the soldering iron until it starts to melt. Try nudging the pins with the soldering iron to move the solder away from the joints. Pull the components you want to remove with the pliers.
Eine weitere Person hat diese Anleitung absolviert.
