Einleitung
Is your toilet seat getting old or broken? Use this guide to learn how to replace your old toilet seat with a new one.
Was du brauchst
Measure the size of your toilet bowl to know what size seat to purchase.
Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
Close caps by twisting them in the opposite direction that you did to take off the seat.
To re-install your previous seat, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
