Einleitung
Is your touch screen is not working? This guide explains how to remove and replace the large motherboard located on the backside of the touch plate. For this repair you will need a black spudger and Phillips #00 screwdriver.
The motherboard is the brain of every electronic device. Its malfunction can cause a failure of the entire device or certain functions. Hence, if you experience malfunction issues it might be caused by a broken motherboard.
Was du brauchst
Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic, and use the tip of the spudger to pry the rubber out.
Remove the two 13.48 mm screws on the bottom of the massage gun with a Phillips #00 screwdriver.
Remove the 8.11 mm small black screw on the edge of circular plate with a Phillips #00 Screwdriver.
Remove the three 7.66 mm silver screws on the large motherboard with the Phillips #00 screwdriver.
