Zum Hauptinhalt wechseln
Toloco EM26 Small Motherboard Replacement
Was du brauchst
  1. Toloco EM26 Small Motherboard Replacement, Small Motherboard: Schritt 1, Bild 1 von 2 Toloco EM26 Small Motherboard Replacement, Small Motherboard: Schritt 1, Bild 2 von 2
    • Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic and use the tip of the spudger to pry the rubber out.
  2. Toloco EM26 Small Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 13.48 mm screws on the bottom of the massage gun with a Phillips #00 screwdriver.
  3. Toloco EM26 Small Motherboard Replacement: Schritt 3, Bild 1 von 2 Toloco EM26 Small Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the 8.11 mm small black screw on the edge of circular plate with a Phillips #00 Screwdriver.
  4. Toloco EM26 Small Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Take off the cap of the massage gun by simply lifting it off the device.
    • Be careful to secure the cap as the back part of the gun may fall.
  5. Toloco EM26 Small Motherboard Replacement: Schritt 5, Bild 1 von 2 Toloco EM26 Small Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Unplug the cable with the small plug from the small motherboard.
  6. Toloco EM26 Small Motherboard Replacement: Schritt 6, Bild 1 von 2 Toloco EM26 Small Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the small motherboard for replacement.
Abschluss
Zachary Olsen
521 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 29
Insgesamt: 242
