Zum Hauptinhalt wechseln
Einleitung
The battery is underneath the motherboard so power off the device before starting the disassembly.
  1. Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top. There are 14 latches that need to be undone.
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. With the screen casing unlatched, locate the right side where the two connectors are.
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. Unlatch the connectors using the plastic opening tool. The orange rectangular connector may have come off in the process of removing the screen casing. The orange rectangular connector may have come off in the process of removing the screen casing.
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. Separate the screen casing from the motherboard casing. Separate the screen casing from the motherboard casing.
    • Separate the screen casing from the motherboard casing.
  6. Unscrew the five 4mm screws using the Phillips #0 screwdriver.
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
  7. Unplug the connector shown near the center of the motherboard using the tweezers. Unplug the connector shown near the center of the motherboard using the tweezers.
    • Unplug the connector shown near the center of the motherboard using the tweezers.
  8. Unplug the second connector using the plastic opening tool. Unplug the second connector using the plastic opening tool.
    • Unplug the second connector using the plastic opening tool.
  9. Remove the motherboard from the casing. Remove the motherboard from the casing.
    • Remove the motherboard from the casing.
  10. After opening the device and removing the motherboard, you will see the battery attached to the frame.
    • After opening the device and removing the motherboard, you will see the battery attached to the frame.
  11. Use the plastic opening tools on both sides of the battery to carefully pry it off of the frame. The battery attaches to the frame with double-sided tape so this should be fairly easy to remove.
    • Use the plastic opening tools on both sides of the battery to carefully pry it off of the frame.
    • The battery attaches to the frame with double-sided tape so this should be fairly easy to remove.
    • In this image, a smaller plastic tool was used on the left side while a larger one was used on the right side.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Oriana Hone
197 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-5, Oliver Fall 2016 Mitglied von UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 12
Letzten 30 Tage: 41
Insgesamt: 6,245
