Einleitung
The motherboard contains all of the device's ports while the speaker, battery, and microphone are separate from the motherboard. Confirm the device is powered off before starting the disassembly.
Was du brauchst
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
With the screen casing unlatched, locate the right side where the two connectors are.
Unplug the connector shown near the center of the motherboard using the tweezers.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
