Was du brauchst
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
With the screen casing unlatched, locate the right side where the two connectors are.
Fast fertig!
Abschluss
