Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The speaker is underneath the motherboard so power off the device before starting the disassembly.
  1. Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top. There are 14 latches that need to be undone.
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. With the screen casing unlatched, locate the right side where the two connectors are.
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. Unlatch the connectors using the plastic opening tool. The orange rectangular connector may have come off in the process of removing the screen casing. The orange rectangular connector may have come off in the process of removing the screen casing.
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. Separate the screen casing from the motherboard casing. Separate the screen casing from the motherboard casing.
    • Separate the screen casing from the motherboard casing.
  6. Unscrew the five 4mm screws using the Phillips #0 screwdriver.
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
  7. Unplug the connector shown near the center of the motherboard using the tweezers. Unplug the connector shown near the center of the motherboard using the tweezers.
    • Unplug the connector shown near the center of the motherboard using the tweezers.
  8. Unplug the second connector using the plastic opening tool. Unplug the second connector using the plastic opening tool.
    • Unplug the second connector using the plastic opening tool.
  9. Remove the motherboard from the casing. Remove the motherboard from the casing.
    • Remove the motherboard from the casing.
  10. The speaker is located next to the battery.
    • The speaker is located next to the battery.
  11. Pinch the speaker at the rubber grommets and tug gently. Pinch the speaker at the rubber grommets and tug gently. Pinch the speaker at the rubber grommets and tug gently.
    • Pinch the speaker at the rubber grommets and tug gently.
  12. Insert the new speaker in the rubber grommet. Use the plastic opening tool to wrap the grommet over the speaker. Insert the new speaker in the rubber grommet. Use the plastic opening tool to wrap the grommet over the speaker. Insert the new speaker in the rubber grommet. Use the plastic opening tool to wrap the grommet over the speaker.
    • Insert the new speaker in the rubber grommet. Use the plastic opening tool to wrap the grommet over the speaker.
Abschluss
Nicholas Maharaj
101 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-5, Oliver Fall 2016 Mitglied von UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 273
