Was du brauchst
Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
Carefully remove the reset button cable (located on the left) and the ribbon cable.
Remove the screen and set it aside.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the logic board cables.
Remove the 3.6mm screws with a Phillips Screwdriver.
After removing the screws simply lift the logic board from the base.
Fast fertig!
Abschluss
