Zum Hauptinhalt wechseln
TomTom GO Live 1535M Reset Button Activation
Was du brauchst
  1. TomTom GO Live 1535M Reset Button Activation, Reset Button: Schritt 1, Bild 1 von 1
    • The reset button is located at the top of the device, close to the charging port. It is a small hole that is .78 mm wide.
    • Insert one end of the paper clip into the small power button hole and press down gently until you hear a "click" sound.
    • Hold paper clip in power button hole for 15 seconds.
    • The device should power on by itself with its factory default settings in place once done. If you do not see the screen power on, go back to step 1 and try repowering again.
Abschluss
Mathias Sagide
618 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 19-4, Blackwell Spring 2014 Mitglied von USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 3,375
