Zum Hauptinhalt wechseln
TomTom GO Live 1535M Speaker Replacement
Was du brauchst
  1. TomTom GO Live 1535M Speaker Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Speaker Replacement: Schritt 2, Bild 1 von 2 TomTom GO Live 1535M Speaker Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
  5. TomTom GO Live 1535M Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Simply lift the speaker up and out of the base to replace it.
Abschluss
Mathias Sagide
618 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 19-4, Blackwell Spring 2014 Mitglied von USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 247
