Zum Hauptinhalt wechseln
Einleitung
After removing the covering for the device, the button cell battery will be located underneath the motherboard. It is important for retaining the information system vital the operation of the device
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the iFixit opening tool to pry open the TomTom Go 60 S.  Start from a corner and drag the tool around the device.
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
  2. Disconnect the screen from the motherboard by removing the yellow flap connecting both.
    • Disconnect the screen from the motherboard by removing the yellow flap connecting both.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Remove all the screws that are marked in the image with a Philips #000 screwdriver.
    • Remove all the screws that are marked in the image with a Philips #000 screwdriver.
  5. Disconnect the 2 battery wires from motherboard. Disconnect the 2 battery wires from motherboard.
    • Disconnect the 2 battery wires from motherboard.
  6. Remove the button cell battery from outer casing to remove battery. Remove the button cell battery from outer casing to remove battery.
    • Remove the button cell battery from outer casing to remove battery.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Tomy Peralta
113 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-6, Nance Fall 2016 Mitglied von USF Tampa, Team 1-6, Nance Fall 2016
USFT-NANCE-F16S1G6
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 656
