Zum Hauptinhalt wechseln
TomTom Go 60 S Motherboard Replacement
Was du brauchst
  1. TomTom Go 60 S Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
  2. TomTom Go 60 S Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device
  3. TomTom Go 60 S Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Once the two covers are separated, use your fingers, to gently disconnect the wires that are connected to the motherboard from the back cover.
  4. TomTom Go 60 S Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Next, you must remove the motherboard from the front screen.
    • Use a Phillips #000 screwdriver to unscrew the screws.
  5. TomTom Go 60 S Motherboard Replacement: Schritt 5, Bild 1 von 2 TomTom Go 60 S Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Separate the motherboard from the front cover, you must disconnect the wires connecting the two.
  6. TomTom Go 60 S Motherboard Replacement: Schritt 6, Bild 1 von 1
    • The motherboard is now disconnected from the front assembly
Abschluss
USF Tampa, Team 1-6, Nance Fall 2016 Mitglied von USF Tampa, Team 1-6, Nance Fall 2016
USFT-NANCE-F16S1G6
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
What is the purpose of single yellow wire ?
is it ok if it is disconnected ? I fear to have unsoldered it or is it just an alone wire ?
Thanks
ugo ceruti - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 1,218
