Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Overtime the motherboard's wires may come apart and make the device stop working. This guide will show you how to replace the motherboard with a new one.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a T-9 Torx screwdriver to  unscrew the four screws on the back cover.
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device. Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover.
    • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover.
  6. Next, you must remove the motherboard from the front screen.
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  7. Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two. To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  8. The motherboard is now disconnected from the front assembly
    • The motherboard is now disconnected from the front assembly
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Becca
202 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-7, Maness Spring 2010 Mitglied von Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 9,846
