Einleitung
This guide will teach you how to replace the battery of the TOMTOM XL if the battery is dead or malfunctioning.
Was du brauchst
Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
After prying both halves apart, they will be connected by two wires.
Carefully set the two halves next to each other making sure not to stress or damage the wires.
Using the tweezers separate the wires connecting the battery and speaker to the mother board.
Place the backside of the battery on the sticky side of the double sided tape.
Using the tech knife, trim the extra tape to the size of the battery.
Remove the back of the double sided tap.
Place the new battery back inside the back panel of TOMTOM XL.
