Zum Hauptinhalt wechseln
TomTom One XL Battery Replacement
Was du brauchst
  1. TomTom One XL Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 TomTom One XL Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: Schritt 2, Bild 1 von 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: Schritt 3, Bild 1 von 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: Schritt 4, Bild 1 von 2 TomTom One XL Battery Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: Schritt 6, Bild 1 von 3 TomTom One XL Battery Replacement: Schritt 6, Bild 2 von 3 TomTom One XL Battery Replacement: Schritt 6, Bild 3 von 3
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: Schritt 7, Bild 1 von 3 TomTom One XL Battery Replacement: Schritt 7, Bild 2 von 3 TomTom One XL Battery Replacement: Schritt 7, Bild 3 von 3
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: Schritt 8, Bild 1 von 3 TomTom One XL Battery Replacement: Schritt 8, Bild 2 von 3 TomTom One XL Battery Replacement: Schritt 8, Bild 3 von 3
    • Reconnect the battery ribbon cable to its port.
Abschluss
DeVhan
401 Reputation
4 Anleitungen geschrieben
Colorado Springs, Team 9-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-6, Panko Spring 2015
UCCS-PANKO-S15S9G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,485
