Einleitung
This guide will show you how to replace or reconnect the charging port to the motherboard.
Was du brauchst
Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
After prying both halves apart, they will be connected by two wires.
Carefully set the two halves next to each other making sure not to stress or damage the wires.
If this is your first time solder then refer to IFixIt's safety guide.
Locate where the charger port goes on the circuit board.
Locate the four connecter on circuit board and charger port which need to be soldered.
Using your plastic opening tool press down firmly on the top of the charger port.
While the soldering iron is hot press it again the four corners of the charger port.
Let the circuit board and charger port cool down for a few minutes.
Lift circuit board up, after making sure its cool, to see if four corners are all connected.
