Einleitung
This guide will teach you how to disassemble your TomTom One XL and expose the power button for cleaning or repair.
Was du brauchst
Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
After prying both halves apart, they will be connected by two wires.
Carefully set the two halves next to each other making sure not to stress or damage the wires.
Using the tweezers separate the wires connecting the battery and speaker to the mother board.
Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
