Zum Hauptinhalt wechseln
TomTom One XL Screen Replacement
Was du brauchst
  1. TomTom One XL Screen Replacement, Back Panel: Schritt 1, Bild 1 von 2 TomTom One XL Screen Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Screen Replacement: Schritt 2, Bild 1 von 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Screen Replacement: Schritt 3, Bild 1 von 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Screen Replacement: Schritt 4, Bild 1 von 2 TomTom One XL Screen Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Screen Replacement, Screen: Schritt 5, Bild 1 von 2 TomTom One XL Screen Replacement, Screen: Schritt 5, Bild 2 von 2
    • Locate the 4 .4mm screws connecting the circuit board to the front panel.
    • Use the T6 Torx screwdriver and remove the four screws.
  6. TomTom One XL Screen Replacement: Schritt 6, Bild 1 von 3 TomTom One XL Screen Replacement: Schritt 6, Bild 2 von 3 TomTom One XL Screen Replacement: Schritt 6, Bild 3 von 3
    Kaufen
    • Locate the ribbon cable connecting the front panel to the circuit board.
    • Locate the white tab locking the ribbon in place.
    • Using precision tweezers push the left and right side of the tab forward.
    • Gently pull the ribbon to disconnect the circuit board from the front panel.
    • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
  7. TomTom One XL Screen Replacement: Schritt 7, Bild 1 von 3 TomTom One XL Screen Replacement: Schritt 7, Bild 2 von 3 TomTom One XL Screen Replacement: Schritt 7, Bild 3 von 3
    • Use the palate knife to pry the screen away from the front panel.
    • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
    • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
Abschluss
DeVhan
401 Reputation
4 Anleitungen geschrieben
Colorado Springs, Team 9-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-6, Panko Spring 2015
UCCS-PANKO-S15S9G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 929
