Einleitung
Before beginning this guide you should have completed guides on removing the back cover and separating the circuit board from the front cover.
Was du brauchst
Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
After prying both halves apart, they will be connected by two wires.
Carefully set the two halves next to each other making sure not to stress or damage the wires.
Using the tweezers separate the wires connecting the battery and speaker to the mother board.
Locate the 4 .4mm screws connecting the circuit board to the front panel.
Use the T6 Torx screwdriver and remove the four screws.
Locate the ribbon cable connecting the front panel to the circuit board.
Locate the white tab locking the ribbon in place.
Using precision tweezers push the left and right side of the tab forward.
Gently pull the ribbon to disconnect the circuit board from the front panel.
Use the palate knife to pry the screen away from the front panel.
Pry between the light gray board and the black boarder of the TOMTOM XL screen.
