Zum Hauptinhalt wechseln
TomTom VIA 1530 TM Screen Replacement
Was du brauchst
  1. TomTom VIA 1530 TM Screen Replacement, Back: Schritt 1, Bild 1 von 2 TomTom VIA 1530 TM Screen Replacement, Back: Schritt 1, Bild 2 von 2
    • Position the device so that the underside is facing up.
    • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
    • Firmly grab the EasyPort Mount and remove it.
    • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
  2. TomTom VIA 1530 TM Screen Replacement: Schritt 2, Bild 1 von 2 TomTom VIA 1530 TM Screen Replacement: Schritt 2, Bild 2 von 2
    • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
    • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
  3. TomTom VIA 1530 TM Screen Replacement: Schritt 3, Bild 1 von 2 TomTom VIA 1530 TM Screen Replacement: Schritt 3, Bild 2 von 2
    • Flip the device over so that the screen is facing up.
    • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
    • It may be easier to start at one of the corners.
    • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
    • This specific device's ribbon cable is torn.
  4. TomTom VIA 1530 TM Screen Replacement: Schritt 4, Bild 1 von 2 TomTom VIA 1530 TM Screen Replacement: Schritt 4, Bild 2 von 2
    • Carefully slide the screen forward, revealing the lower portion of the motherboard.
    • Remove the 3.6mm screw using the JIS #00 Screwdriver.
    • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
  5. TomTom VIA 1530 TM Screen Replacement: Schritt 5, Bild 1 von 3 TomTom VIA 1530 TM Screen Replacement: Schritt 5, Bild 2 von 3 TomTom VIA 1530 TM Screen Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the battery and speaker cables.
    • Unlatch the motherboard from the case.
  6. TomTom VIA 1530 TM Screen Replacement, Motherboard: Schritt 6, Bild 1 von 2 TomTom VIA 1530 TM Screen Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Wedge a spudger between the white plastic latch and the black connection port, disconnecting the gold ribbon cable.
    • Slide the gold ribbon cable out of the port.
  7. TomTom VIA 1530 TM Screen Replacement, Screen: Schritt 7, Bild 1 von 3 TomTom VIA 1530 TM Screen Replacement, Screen: Schritt 7, Bild 2 von 3 TomTom VIA 1530 TM Screen Replacement, Screen: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to unlatch the screen from its case.
    • We recommend starting on the side with the gold ribbon cable as the latches are more tricky.
    • Unlatch the screen corner by corner instead of an entire side at one time.
    • The tearing sound is the adhesive holding the screen to the case. It will re-stick when you put the screen together.
Abschluss
Cal Poly, Team S12-G2, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G2, Banghart Winter 2018
CPSU-BANGHART-W18S12G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 338
