Einleitung
Use this guide to remove or replace the screen in the TomTom XL.
Was du brauchst
Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
Starting at the corners, carefully pry up the screen bezel.
Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
Remove the frame from the housing.
Lifting from the upper edge of the screen, tilt the screen away from the device.
Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
Two Phillips #00 screws are located at the bottom of the first picture.
The third screw is hidden under the orange ribbon cable, near the screen.
Flip the screen and motherboard over.
Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
Disconnect the speaker cable connector from the motherboard.
Remove the motherboard and screen from the housing.
Using your thumbs or the flat end of a spudger, push back the white tabs on the display cable ZIF connector.
Gently pull the orange display cable out of the ZIF connector.
