Was du brauchst
Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
Using two hands, hold both ends of the device and snap the two plates together.
3 weitere Personen haben diese Anleitung absolviert.
