Ersatzteile
Kein Ersatzteil erforderlich.
  1. Peel back the sticker on the bottom of the device to reveal the two screws.
    • Peel back the sticker on the bottom of the device to reveal the two screws.
  2. Unscrew the two t-5 screws using a T5 Torx screwdriver.
    • Unscrew the two t-5 screws using a T5 Torx screwdriver.
  3. Wedge the flat head of the screwdriver into the edge of the device.  Gently lift the screen from the cover.
    • Wedge the flat head of the screwdriver into the edge of the device. Gently lift the screen from the cover.
  4. Release the yellow ribbon cable.
    • Release the yellow ribbon cable.
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Identify the green motherboard.  Unscrew the three screws holding the board in place.
    • Identify the green motherboard. Unscrew the three screws holding the board in place.
  7. Remove the motherboard from the back plate.
    • Remove the motherboard from the back plate.
  8. Unplug the battery from the board.
    • Unplug the battery from the board.
  9. Plug the new battery into the white receptacle on the green motherboard.
    • Plug the new battery into the white receptacle on the green motherboard.
  10. Transfer the green motherboard back into the back plate and secure it with the 3 screws.
    • Transfer the green motherboard back into the back plate and secure it with the 3 screws.
  11. Reconnect the yellow ribbon cable and connect the screen and back plate back together.
    • Reconnect the yellow ribbon cable and connect the screen and back plate back together.
  12. Insert the t-5 screws and tighten to secure.
    • Insert the t-5 screws and tighten to secure.
  13. Replace the label to cover the screws.
    • Replace the label to cover the screws.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Mike Sollars
471 Reputation
3 Anleitungen geschrieben
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Mitglied von WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 3,168
