Zum Hauptinhalt wechseln
TomTom XXL 540 Back Panel Replacement
Was du brauchst
  1. TomTom XXL 540 Back Panel Replacement, Remove the screws: Schritt 1, Bild 1 von 2 TomTom XXL 540 Back Panel Replacement, Remove the screws: Schritt 1, Bild 2 von 2
    • Using tweezers, peel back the sticker on the bottom of the device to reveal the two T5 screws.
    • Use the T5 Torx screwdriver to unscrew the two T5 screws.
  2. TomTom XXL 540 Back Panel Replacement, Remove the faceplate: Schritt 2, Bild 1 von 1
    • Use a flat edge screwdriver to pry open the faceplate.
  3. TomTom XXL 540 Back Panel Replacement, Remove the ribbon cable: Schritt 3, Bild 1 von 1
    • Release the ribbon cable that connects the two sides.
  4. TomTom XXL 540 Back Panel Replacement, Remove the screws from the motherboard: Schritt 4, Bild 1 von 1
    • Identify the green motherboard.
    • Use the T5 Torx screwdriver to unscrew the three T5 screws that hold the motherboard in place.
  5. TomTom XXL 540 Back Panel Replacement, Remove the board and battery: Schritt 5, Bild 1 von 1
    • Remove and disconnect the motherboard and battery from the back panel.
  6. TomTom XXL 540 Back Panel Replacement, Re-attach the board and battery: Schritt 6, Bild 1 von 1
    • Attach the motherboard and battery to the new back panel.
Abschluss
Mike Sollars
519 Reputation
3 Anleitungen geschrieben
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Mitglied von WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,308
