Einleitung
Have fun with this great disassembly guide!
Was du brauchst
The full product in its original state.
Remove the nozzle by pressing the white button on the top of the product just under the name of the brand.
Remove the big parts that are inside of the nozzle. These parts consist of a plastic structure with a filter.
Remove the rubber fitting from the inside of the nozzle by pulling it from the metal pieces.
Remove the blue switchbutton from the upper part of the nozzle by putting a momentum on the edge. After you have this signature move you can remove the brush. You can see the video for the signature move.
Remove the blue switchbutton from the upper part of the nozzle by putting a momentum on the edge. After you have done this signature move you can remove the brush.
Right now the whole nozzle is disassembled, except for two small steel rings. These will break if you try to remove them.
Remove 4 screws on the side and 1 screw on the bottom. You'll do this by crosshead screwdriver size number 1.
Remove the last screw with a number 1 screwdriver, next to the electro motor to release the motor + turbine.
